Can't see studs
Can't see studs
Message 1 of 22
Can't see studs
Hi, I'm just starting out with Revit. I'm just practicing with stud walls. How do I view the studs through the walls? I created the stud under structural framing in the families section. I've tried everything.
Mark
Replies (21)
Message 21 of 22
Hi Mark,
I'm trying Revit for the first time (in like 5 years) and I'm looking to create some studded walls with insulation between the studs; would you have any advice on a tutorial of sorts for this? Any advice would be greatly appreciated!
Message 22 of 22
constantin.stroescu
maybe this screencast can help you a little:
There two methods described :
  • The first one is only for 2 d presentations : using Component > Repeating Details and Detail>Insulation
  • The second one is a 3d that use a custom Curtain Wall
https://knowledge.autodesk.com/community/screencast/5fca75ee-1708-48d7-ab66-486dc667aa2b
Constantin Stroescu
