- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am working with a file that links to two RVT models, and a DWG model that I have imported as a family.
I am able to produce plans and sections without issue, however when I create an RCP it is blank (I can't see any elements from any model).
Curiously; when I click and drag from right to left I'm able to see the model as it should display. When I release the click the models are selected, but they are no longer visible (I just see the pin icons for each).
I've checked my phasing and levels. I've also checked depth clipping - when I change the depth clipping options it affects what I can see during the click and drag.
I'm a bit of a noob so thanks in advance for any suggestions.
Cheers, Pete
