Can't rotate floor pattern
Hello all,
So I can't figure out how to rotate my wood floor pattern so it can run parallel to my walls. Is there a way to rotate the pattern?
If it is a model surface pattern then use Align tool.  If it is a drafting pattern then no luck.
Corsten.Au
Hi
Click " TAB" and select the hatch pattern " Single Line" and then rotate the way you want...
You can align that as well as @ToanDN mentioned.
Cheers!
Corsten
Building Designer
