Can't Place Wall Sweep
PhilvK
Advisor Advisor
Message 1 of 12
PhilvK
I am unable to place a sweep on a wall in a particular view - nothing happens when I hover over the wall. The sweep does work as expected however on the same wall in another view. Any suggestions on what may be causing this?
Replies (11)
Message 2 of 12
Try placing it in 3D View.
Message 3 of 12
Is Select By Face turned off?
Message 4 of 12
PhilvK
Nope, that's not it. I'll keep ;looking and let you know.
Message 5 of 12
Is the Wall Sweep Category turned on in the View?
Message 6 of 12
PhilvK
Yep
Message 7 of 12
You say that you aren't able to place it in one particular view.  Can you place it in any other view?
Post your RVT here if you want us to take a look and see what's going on.
FWIW: Maybe this list of 33 contains a clue:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Message 8 of 12
PhilvK
It works OK in the view I am having the problem with when I isolate Walls and Wall Sweep categories,
Message 9 of 12
So, problem solved; right?
Message 10 of 12
PhilvK
Problem solved? Not really. I want to find out why the problem is happening in that view only, but it's not preventing me from adding the sweeps since I can easily add them in other 3D views of the same wall, and so far all 2D views. Thanks!
Message 11 of 12
PhilvK
I can't post the model due to Owner's wishes, but I just discovered this interesting behavior:
When I select the wall I want to place the sweep on (at the green circle), the floating image of the sweep (highlighted in yellow) appears seemingly perpendicular to the wall I'm selecting. The other sweeps are at the orange arrows.
Message 12 of 12
@PhilvK wrote:
...I want to find out why the problem is happening in that view only...
Could be nothing more than a corrupted view. It happens inexplicably sometimes - in every Version.  Autodesk even publishes a solution for it.  Delete the corrupt 3D view and recreate it.
How to recreate a view with an issue in Revit (autodesk.com)
