Can't move object to workset
Hello
Im trying to move object within a worksharing model, but when I select objects the workset parameter is greyed out. The objects are already in a workset but I cant move them to another one, they are not pinned or anything.
Does someone know how to move them?
ennujozlagam
@Anonymous hello, Elements must be editable to change their workset.  If under Identity Data, Workset 1 is grayed out, that means the element is not editable and you can't change the workset.  So, right click on the element and select "Make Elements Editable" to change the workset.  The easier way to do it is to make sure everyone has sychronize and saved to central and then gets out of the file.  Then make the entire workset editable, and move elements to the proper workset as needed. thanks
What is that "object"?
The object is curtain panel. I can move the curtain wall but not the panels.
Ok will give it a try. Thanks.
You cannot assign workset to curtain panels.
carolagryma
Observer
Observer
I had the same issue and the answer above did not help in my case but I thought I would log in to write something that helped me. It is not rocket science really but at least it made the change faster. What I did was create a new workset that was hidden and showed only the old one. Then I kept moving the old items I wanted to the new and it made it a lot easier to make sure I did not miss any walls, windows or doors in my case. I thought there may be an item that I will find later that somehow was locked but after cleaning the entire floor plan I could not figure out what item was causing the issue. I mainly had room tags left in the end but the odd thing is that I deselected them several times from the start anyways.
