- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I got a package of documentation in dwg comprising various projects (Structure, HVAC, Architecture, etc).
Everything is ok with all CAD files, only there is a problem with Architecture, that all files I can't link or import to Revit.
This errors appear:
Import detected no valid elements in the file's Paper space. Do you want to import from the Model space?
Import detected no valid elements in the file's Model space. Do you want to import from the Paper space?
I usually solved this problem by copy-paste the contents to another dwg or saving the file in the previous version CAD, but it doesn't help now
I saved the DWG in 2018, 2013, and 2007 versions (I am using Revit 2022 but also tried to do it in 2023
I copy all items to another file from the original DWG. (I also tried pasting the file into another file using Bind, Insert)
I also know that the documentation was made with AutoCAD Architecture 2013, but I don't have any ACA elements, just simple Autocad.
I have no idea how I can repair it. Can somebody help me?
I have attached one of this dwg and a screenshot of the error. Thanks
