Can't join roofs
Can't join roofs
Message 1 of 9
Can't join roofs
Hi guys, i am trying to get these 2 roofs to join, but when i try i get an error message saying that it can not be joined. Am i doing anything wrong?
Thanks in advance
Replies (8)
Message 2 of 9
Are you using the "Join/Unjoin Roof" tool? Modify your sketch boundary to stop short of intersecting with the roof it's going to join with. Then use the "Join/Unjoin Roof" tool to make the join condition.
Message 3 of 9
chrisplyler
It doesn't need to stop short of any intersection...it just needs to stop short of being fully through the surface already.
AND the width of it needs to fit entirely within the joining surface. I had to cheat the floorplan a bit when I worked on that corner because it cannot join as is.
Message 4 of 9
Thank you Chris for that information.
Message 5 of 9
constantin.stroescu
and why don't you just use one single roof for this?
Constantin Stroescu
Message 6 of 9
I have tried, and it doesnt work correctly
Message 7 of 9
Ah apologies, i didnt see the screen shot you supplied, i will try it now! thank you!!
Message 8 of 9
chrisplyler
That's what I was talking about in the other thread. That corner doesn't geometrically work the way the dwg file shows it.
Message 9 of 9
Ah that's what was causing me issues! Thanks for your help. Much appreciated
