I have Windows 7 operating system, and I recently reinstalled the operating system. For some reason I can't install Revit, and after I installed Microsoft Visual C++ the same problem raised again. Here I attatched the screen shot, hope I can know the solution, thanks!
hi, tried to read this, maybe could help you. thanks.
http://forums.autodesk.com/t5/revit-architecture/revit-2015-unable-to-install/td-p/5410273
Hi, ennujozlagam:
Thanks for your reply.However, I think this method is not for my case.
But the good news is, recently when I search this kind of question about "The File name, directory name, or volume label syntax is incorrect", I find a video that told me I just need to copy and paste the installation package into C: drive (where you install revit) and then install revit here. It is simple, I don't know why it can solve this problem but it really worked!
Here's the link:
