REVIT 2015: Unable to Install
Hello sir/miss,
I am a student which I had a problem with Revit 2015 which it said Revit 2015 is already install. So I search Autodesk instruction on how to solve this case which it leads me to Revit 2015 Clean Unistallation. Althought I did remove Autodesk BIM 360, delete some files from Regedit which following the Autodesk provider instruction. I am still have an issue of Revit 2015 is already install. Due to that, I unable to install Revit 2015. If I manually install Revit 2015 without using installer, it just make a new folder in Program Files without a proper install in Control Panel then I would like to repair and it said 'An error unistall Revit 2015. Do you would like to remove from Control Panel?' I can use the program normally but I will be having an issue of library families. After that I will be having issues after close down the program of ...dll missing files.
Does Autodesk has a proper software nor program which could help clean up the system nor automatically delete the file which having me to searching all does typical files yet in the end, it still does not work.
Before Install Revit 2015, I have Revit 2014 with me and it work perfectly. Could Autodesk help me out in this case with problematic of Revit 2015 (Student Version)?
edwin.prakoso
Try to uninstall it using FIxit here: http://support2.microsoft.com/mats/program_install_and_uninstall
It should fix the uninstallation issue.
Then try to install it again.
Cheers,
Edwin Prakoso
Accordingly Fixit program, Revit 2015 doesnt shown up but I have remove it accordingly Autodesk Revit 2015 Clean Uninstall due to some corrupted files. After I clean/delete files and tried to reinstall back. This is what shown up by the below attachments. Installation setup told me that I 'had install Revit 2015' but Revit 2015 is completely remove and it don't appear under my control panel (add or remove program panel). I dont know what is going on right now, there is something blocking me and clearly it is not a virus as 100% clean system which I run full scan.
The solution:
 1. Manually run rvt2015.exe to install  Revit 2015 but it doesn't properly install rather than just extract a folder
     (when trying to unistall from 'add&remove program, it said an error to unistall it.)
 2. Run Fixit and select Revit 2015
 3. Run Troubleshoot (Recommanded) and choose option (Installing / Unistalling)
 4. Fixit will automatically recommanded you to unistall it
 5. Wait for a few second and Fixit completely remove Revit 2015 from the system
 6. Rerun back Autodesk Manager and install Revit 2015 by a proper manager
Thank you so much !
