Can't find the view range button
 Hi all,
Can you tell me how to make the View Range button appear, i can not find it?
Thank you!
dzanta
View Range is an instance property of the view you are currently in.  Ensure you have nothing selected and no command active.  It should appear under the Annotation Crop Box.  If not, do a repair on Revit
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thank you,i did what you told but still couldn't find it.
Anyone knows?
dzanta
have you done a repair on revit?
 Yes i did!
I found it now, when i open a project and chose a plan, it appear. But when i do a new one, i still can't find it.
I just started Revit yesterday and i have no idea, so maybe it isn't an error? Is it necessary to have a plan or something kind of it  in the project in order to make the view range button available?
dzanta
view range command is for plan views only.  I assumed you were in a plan view.
worse case, you may need to do a reinstall of Revit.
