Can't Export Portrait to Portrait Sheet from Revit to Cad.
nomaankhatri
Message 1 of 8
nomaankhatri
I have around 200 A4 sheets in Revit which are in Portrait orientation, when I export them to CAD the come in Landscape orientation.
Is there any setting or trick by which I can control the orientationOriginal Revit SheetExported from Revit to Cad while exporting from Revit?
Replies (7)
Message 2 of 8
@nomaankhatri Just change your default plot settings in Autocad to the size you want and it will show up that way. 🙂 (Options - Plot and Publish)
Message 3 of 8
syman2000
You can use the DWGCONVERT and load all your 200 DWGs. In the setting, you can change the page setup and load your template portrait plot.
Message 4 of 8
nomaankhatri
Does Not work  😞
Message 5 of 8
KrisAribal
It's obvious that your problem is the CAD not Revit.  Change your plot area to window select the edges of the sheet and apply layout.export.PNG
Message 6 of 8
ennujozlagam
can you share just one file/sheet so we can check. thanks
Message 7 of 8
ennujozlagam
hello, just a wild guess, just install the latest updates from autodesk, sometimes it fixed the issues. thanks
Message 8 of 8
nomaankhatri
Karibal,
I know I can do this, but my problem is I have more then 200 sheets and I need to perform this task every week for Submitting my drawings,
I assume the problem is with Revit export, as when the sheets are in oriented in Landscape mode revit doesn't any problem exporting them.
Thanks.
