Bespoke Brick Pattern
I am trying to create a new pattern for a bespoke brick, see attached:
brick: 218x65mm
vertical joint: 10.18mm
horizontal joint: 10mm
Help appreciated.
David_W_Koch
This should work for you, for the brick outlines.  Did you want the diagonal crosshatch as well?
[The forum was not accepting my reply with a PAT file attached, so I put it in a ZIP file.]
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Pattycake_Kyle
Here you go: https://pattycake.io/pat/YlyAYAk5XbM
Just click download at the top. It's made with one of our calculators, so you can adjust the spacing and everything then redownload if you need to adjust for whatever reason.
Cheers.
In RevitIn Revit
Pattycake Pattern ViewPattycake Pattern View
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Pattycake_Kyle
Woops, hadn't refreshed and didn't see your reply. Sorry.
You solved the upload correctly --- I learned this too from user @pendean ... ""pat" is the Windows screensaver file extension too, and can be malicious if desired to be so: most of us simply ZIP when sharing them around here."
www.pattycake.io
no diagonal crosshatch, thanks
hugha
Why does the web generator create a pattern with 8 elements, doubling its complexity compared with David's ability to create the same fill arrangement with four?
HatchKit also manages with four within your Revit project -  no web access required :
;        Written by HatchKit Team Edition
;        HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
;        www.hatchkit.com.au/
;%VERSION=3.0
;%UNITS=MM
*Brick218x65mm
;%TYPE=MODEL
0,0,65,114.09,-75,218,-10.18
0,0,0,114.09,-75,218,-10.18
90,218,0,75,-114.09,65,-85
90,0,0,75,-114.09,65,-85
hth,
Hugh
hth,
Hufgh Adamson.
