Can't enable collaborate
So I am trying to enable worksharing on a revit project. Worksets is greyed out so I tied to enable collaborate and selected collaborate with network as I usually would.  Then a pop-up saying "Initiate Collaboration failed. Check the journal for more details." I haven't seen this before an ddon't know what to do to fix it. I checked to make sure it was saved as an .rvt file and it is, any help would be much appreciated thanks!
Sahay_R
Which version are you in?
This is a fix for 2015 and 16 - possibly could work for 17.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
I accidentally closed out of the model and reopened it and somehow that fixed it haha. You have to love technology. THanks for the response though!
I have a problem with collaboration in Revit 2019. I get error: Initiate Collaboration failed. Check the journal for more details.
cglaude
I have the same problem with Revit 2019 to BIM 360 Docs
''Failed to launch collaboration''
