Schedule Key Door Tagging
Message 1 of 8
Hey All,
I'm trying to find a way to allow for a Door Tag to have an assigned schedule key number referenced. I'm using a schedule key as my hardware schedule which is working great however I would like to a Tag on my floor plans showing what hardware group it is in. So far the only way I have been able to get any information from the schedule key onto a tag is though the Comment parameter.
Is there another way to do this that I'm missing?
Replies (7)
Message 2 of 8
dzanta
I do not believe this is possible the way you want.  The Parameters listed in the Edit Label for the tag you are creating for doors list built-in/pre-programmed parameters that look at the door.  You cannot use a shared parameter in this situation because the shared parameter doesn't drill down into the key schedule and key name.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Sahay_R
The only way that I can think of doing so is through Shared Parameters, which don't work with key schedules. Feel free to vote up the idea here -
https://forums.autodesk.com/t5/revit-ideas/allow-shared-parameter-in-a-key-schedule/idi-p/6254607
However, they do work with regular schedules, if that option could work for you.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 8
@Anonymous
Add one of the unused built-in parameters to the Key Schedule and use it to tag.
Message 5 of 8
dzanta
can you clarify the solution?...isn't the Comment considered one of the built-in parameters he is already using?...I though he wanted to pull the Key Name directly out?
Message 6 of 8
I do wish to just pull straight from the Key name. but if there is no way to do that then linking it to the comment is the best work around
Message 7 of 8
dzanta
that's what I initially thought.  I will put in a tech support case to autodesk for this one...
PM your Revit serial number so I can put it in the case as well as your name, company name, phone and email address to they can copy you on all the emails.
Message 8 of 8
Yes.  Comments is one of the built-in parameters that can be used.  I use Finish parameter to present Hardware Group Number because I don't need it for any other purposes.  Even if I do, I can create another parameter for Finish because it doesn't required to be in a tag.  It's about priority.
