Can't edit Type Comments in schedule view
brian
Message 1 of 9
brian
I just started using 2019.0.1 and I can't edit Type Comments from a schedule view. I'm sure this worked in the past.
Anyone else having this issue?
Replies (8)
Message 2 of 9
What are you scheduling?  Are the rows un-itemized?  I can edit Type Comments in a schedule view in 2019.
Message 3 of 9
brian
I'm working with a footing schedule, but I have the same problem with all schedules. Changing to "itemize every instance" does not fix it.
Message 4 of 9
Are the cells locked and you cannot type anything in? Or you can type in the value but Revit refuses to accept it?
Message 5 of 9
brian
I can type in the cell, but Revit does not accept it. Just tried it on another machine in the office, and it has the same problem.
Message 6 of 9
Does it happen to any files of just this one file?  Try to save to a new central. Try it on a brand new file see if it persists.
Message 7 of 9
brian
Just tried a different file that is not work-shared, and it is the same.
Message 8 of 9
Corsten.Au
Hi
If the Element is from " Linked File " then Revit may now allow editing any Type Properties of that element..
also its little weird, when the Type comment is changed, rather than clicking " OK" try " ENTER"
have a check...
Best luck
Corsten
Building Designer
Message 9 of 9
brian
The scheduled elements are not in a linked file.
If I type in the cell and hit enter twice on the keyboard it works.
Why does the "OK" button not work? Is there another place I should report this bug?
Thank you for the help!
