Can't Edit Dimension Length
jmartucci2
jmartucci2
I'm making a lighting layout plan and on one of my views I'm unable to edit the dimension length between my lights. It was working on a lighting layout plan on the first floor, but when I went to the second floor of the building I'm unable to edit the dimension length, even though I'm using the same exact light fixture family and the same exact dimension style.
CADmonkey_UK_Building_Services
At a guess, your Dim in Jpeg#1 is attached to something other than the Light Fitting.
What happens if you move the Light?
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
jmartucci2
When I move the light the dimension moves also
Do you see Activate Dimensions button in the Option bar under the Ribbon when you select the light?
