Can't Download the English Model Checker and Power Bl Dashboard
ahmad_esmatPL545
ahmad_esmatPL545
i Tried Following the Steps in the file attached on the website: https://interoperability.autodesk.com/modelchecker.php
or try to enter the download link
https://www.biminteroperabilitytools.com/dashboard.zip
but the file is missing as you can see in the attached image
Those Extension are available through your autodesk.manage.com portal.
JasonKunkel
I find no link to dashboard.zip on the page you reference: Autodesk Model Checker for Revit
Where exactly is this link to download?
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
handjonathan
Hi @ahmad_esmatPL545
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
ahmad_esmatPL545
UNFORTUNITLY THE MATTER WASN'T SOLVED AS I'AM TRYING TO FIND A PATH OR THE Model Health Checker Power BI dashboard file and templates from Autodesk’s Interoperability Tools for Revit.
m_meligyE72TH
After a little digging online, I found it here:
https://interoperability.autodesk.com/downloads/dashboard.zip
