Can't create run by this sketch
fxhu
Message 1 of 8
fxhu
Hi
i tryin gto creat stairs and i did everything allright and its still say the sketch is invaild
Boundaries - connected
Riser - all of the between boundaries
Stair Path - offset to the middle between the boundaries.(the top isnt work even if its not cutted)
Replies (7)
Message 2 of 8
GustavoUbriaco
you have to put the stair path
Gustavo Ubriaco Contreras
Message 3 of 8
fxhu
stair path is allready exist
Message 4 of 8
GustavoUbriaco
Oh I'm sorry I've seen that you have the stair path maybe the chamfer in the stairpath makes the error i make a similar excercise and not found any mistake maybe overlapping lines?
Message 5 of 8
fxhu
I tried to move a little the riser where they meet close to the landing area,
the problem now that it cant make stairs
Message 6 of 8
GustavoUbriaco
or can you share the project?
Message 7 of 8
fxhu
I found the problem,
the risers in the red circle cant connected to the end of the boundaries in thus areas.
מדרגות פתרון.jpgprobably i will found my self do this again soon, so dont delete this soloution.
Message 8 of 8
Create the stairs with 3 runs and convert the middle to sketch to make the curve, add the landings and convert them to sketches to make the shapes.
