Message 1 of 10
08:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
this part is the problem try to divide in 2 runs the stair
Gustavo Ubriaco Contreras
Riser ending in riser, must end in boundary.
Just change that and will be ok
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
I just tried it and it still wont accept it, sorry if this is simple solution, i'm new to revit
i see in your image an error close here with boundary.
here you are an example and file "updated"
still crossed, try to move the boundary a little so that the black lines do not touch. I tested it and it works for me.
But it may be that you have some configuration in the type of your ladder that you are preventing, perhaps the option of using two ladders works best for you.
you don't have to apologize, it's okay to be new to something, we've all been there once.
I still can't figure it out. would you mind taking a look? the stairs are are on the left of the site plan
try to see a picture of the place to confirm the shape of the ladder, there is a planter that may be hindering understanding
As it is a strange configuration, you can consider using a component model in place, and classifying it as stair.
But even so I tried to do it using the Stair tool and it is necessary to make a small adjustment to be able to work.
But even so I tried to do it using the Stair tool and it is necessary to make a small adjustment to be able to work, even so there is an error when trying to use the "cast-in-place" type.
I can't send what I did because my RVT is 2020 and yours is 19.
