I am trying to create a room/room tag for a project, but every time I try to create a room it tells me that: Multiple Rooms are in the same enclosed region. The correct area and perimeter will be assigned to one Room and the others will display "Redundant Room."
I can see ALL of the rooms in the plan (they highlight blue and show their tags) so I don't thing that it is a visibility graphics issue, and the room tag does not show when I Reveal Hidden Elements.
Also, When it displays the Multiple Rooms are in the same enclosed region..... message I clicked "show" to try and see where the room might be hiding in the file, but then Revit returns a message that it "Could Not Find A Good View"
Any help would be much appreciated!
Check:
-Room separation lines hidden?
-Phasing problem?
-Workset problem?
-Linked file not set to Room Bounding?
-Design Options?
When the warning displays, click Expand>> and open Warning 1 in the treeview.
You'll see 2 rooms with an id. The first is probably the conflicting existing room. Make a note of the id.
You can select that room:
In the properties window you can see which room it is, name / level / phase etc. and hopefully analyse why you are not seeing it.
