Hi All,
I am trying to copy room names from one floor to another. When I copy to clipboard and then select the drop down menu for paste in revi, I do not et an option for align to selected levels. I do have option for Align to selected views.
Why is this happening.
Solved by RDAOU. Go to Solution.
When you say room names, are you referring to room tags? Is the view type you're trying to copy into the same as the view you're copying from? For example, you cannot copy elements from a plan view to a sheet view.
By room name you mean the Room Tag...Room tags require a host ie: the room on the second floor need to be existing/already placed
You might first want to Copy/Past the room itself to the Second floor. Rooms can be pasted Aligned to levels or views. (You can also select both Room and Tag and paste them aligned to view on the 2nd floor - the room has to be included in the process)
When you have the tags selected you wont have Align to level...Open the plan view of the level you want to paste to and use paste aligned to current view
Otherwise as mentioned above...Copy Rooms only paste aligned to Level 2...then do the tags separately.
If you are not sure what you are selecting...click the selection filter >> uncheck all and keep only rooms checked
Selection Filter is on the bottom left corner or on the Ribbon
