Hi All,
So when I have columns running from base level to the 2nd level of my building. I notice that if I were to snap walls to either sides of my column. I do not get a room. I need to run my walls through the column, in order for revit to recognize that area as a room. Any reasons why this is happening?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Are the columns checked as Room Bounding on the Properties panel?
Yes they are. I have attached a screenshot. Note how there are walls on either side of the column, but the room consideration goes beyond that,
There seem to be no bounding element to split the room...
That fixed it! My constraints for the wall were not correct. Great! Thanks for your help.
