Solved by constantin.stroescu. Go to Solution.
Don’t you just love when you accidently stumbled on the problem and find your own solution!
I had a View Template applied to the Site Plan, which seems to deactivate the ability to re-scale the view
Yes, I suppose this is the cause....
Perhaps : View Scale is checked in View Template....uncheck it in order to can choose another scale
Constantin Stroescu
Constantin Stroescu
What about if you donot have any template?
My scale is to 1:200
but when I inset the sheeon on the title block, I can change the scale, but the title does not change the scale.
and still shown at 1:125 on grey as the view title
It could be that your sheet properties for scale is only text notes & not a parameter assign for 'scale'. For your sheet to reflect back the scale, you can try add label/ edit label and change it to 'scale'.
we use scale
1:10
1:20
1:25 ??
1:50
1:100
1:125 ??
1:250 ??
1:500
1:1000
1:5000
how can i change or add scale to revit? Is possible?
Katarina
we use scale
1:10
1:20
1:25 ??
1:50
1:100
1:125 ??
1:250 ??
1:500
1:1000
1:5000
Katarina
simply type the new desired scale:
Constantin Stroescu
Constantin Stroescu
Thanks, i didnt see.... 😉
It works! Thanks a lot😊
