Does anyone knows how to properly wrap a finish in an architectural floor like this? I tried searching in the forums and the problem exists since the early versions of the software, but it seems like we don't have a solution yet.
I'm currently using Revit 2019.
Thanks!
Solved by RDAOU. Go to Solution.
You can use any of the following
1. SLAB edge
2. Model in place sweep
3. Line based family
4. Use a wall and join geometry
5. Use a beam
6. ...etc there are a couple of more ways to do that
Thank you for the reply!
So, doesn't Revit have a way of doing this within the family properties? Shouldn't be the case for Autodesk to include this feature?
No there is no end wrapping option in floors and roofs..
If you are asking my opinion if Autodesk should or shouldn't add the option...I would also say no because what you are referring to as wrap is actually either a slab edge / beam or part of the envelope's walls (ie. an entirely different trade) ... where as in walls, the end wrap is different situation ...So personally I prefer using a beam or anything else over a built in option to wrap the slabs end.
Nonetheless, you can always submit that suggestion in the Ideas Forum.
