Can not Split railing
nguyenquangchung288
Message 1 of 9
nguyenquangchung288
<div>Hi guys. I want split railing but can not do it in this my project. when i want delete a part railing but them are a block. and have warning: "Cannot split railings with extensions. To split the railing, delete the extensions first, or use the Reset Railing command." (pic 1) however, if i make it in new project. i can do that (pic 2) Thanks to everyone for help.</div>
Hi guys.
and have warning:
Replies (8)
Message 2 of 9
You can temporarily change the railing to a type with handrail/top rail types having no extensions, split the railing, then change it back to the original type.
It depends on your railing configuration and layout, occasionally it is better just to model separate railings instead of splitting one.
Message 3 of 9
nguyenquangchung288
Thanks your reply.
 extension style of This toprail is none.
But it can not split. The purpose of cutting this railing is to erase part of it, because it is currently a block
Message 4 of 9
Share your model here and indicate where you want to split (I guess the top landing).
Message 5 of 9
Message 6 of 9
nguyenquangchung288
I send you my model
https://drive.google.com/drive/folders/1Vean1lsuJ9SgUfafZpWWbIqL8UMOjh8X?usp=sharing
I was make like Your video send . But still don't split
Thank you.
Message 7 of 9
Change this Length to 0, not 100.
After that it can be splitted just fine.
Message 8 of 9
nguyenquangchung288
Oh my G. :)))
i have been groping this issue all day today without knowing the cause of this.
thank you so much.
Message 9 of 9
IU_NguyenLong
cảm ơn anh Toàn ạ.
