Path of Travel Lines
MGD-Trevor
MGD-Trevor
Hello, does anyone know if there is a way to make the path of travel lines follow a straight line and turn at right angles? I have tried manipulating some of the settings and I cannot seem to get it to work without adding a bunch of waypoints (which isn't a bad option if I could change the arrowhead type for each waypoint - not a large dot).
Thanks!
That would defeat the purpose of the path of travel analysis algorithm but I too have to do that to please the plan checkers.
So far I have found no other ways other than adding waypoints.
The Path of Travel generates a line indicating the shortest path of travel between the 2 selected points.
...nothing preventing you from hiding the obstacles in the View.
Maybe you are taking about the radius?  If so, read this:
Path of Travel Calculations | Revit 2020 | Autodesk Knowledge Network
RDAOU
A new first timer...Toan will win. kinda his specialty lol
