Hi
I have created a two level building and have also created RCP Plans. I have drawn in a 600x600 ceiling grid. I can not see the ceiling grid. I have tried copying the settings in the view range from other projects but still can not see the grid in this project.
My ceiling heights are 2585mmH and slab thickness 150mm. What should my view range settings be? Is there another setting that I need to turn on to see the grid?
Thank you
Hi
Thank you
It might be the view range - try something like this:
But it could be a number of other things, such as:
Does your ceiling have grid lines?
Are ceilings switched on?
Is there any phasing?
Is it on a switched off workset?
in the structure of he ceiling, is the proper finish applied to show the ceiling grid? can you add a screen capture of your view range setting for your Ceiling Plan?
Howard Munsell
Howard Munsell
The top of your RCP view range should be higher than 2850 mm. For consistency, just set it to Level Above + Offset = 0.
By the way, have you noticed that your second level floor is sitting on top of the level? For all intents and purposes, the floor should be at the level or you will encounter various issues with room bounding/disappearance later on.
