can not open the Revit file
Yara-architecture
Message 1 of 30
Yara-architecture
hello, how to recover file when Revit gave me this message (can not open the file there is missing many elements), how to solve that, thank you in advance.
Replies (29)
Message 2 of 30
ennujozlagam
have you try to tick audit before opening the file and see if helps. thanks
Message 3 of 30
Yara-architecture
hello, what do you mean by that (tick audit)?
thank you for the answer
Message 4 of 30
martijn_pater
See attached.
Message 5 of 30
Yara-architecture
hello, gave me this message, and that what does do for the file?
Message 6 of 30
ennujozlagam
did you upgrade your file in a higher version? open your revit program first then open the file. yes that is correct tick the audit box before opening the file. thanks
Message 7 of 30
Yara-architecture
i did what you had mentioned, but it gave me this message( that I attached), so I choose yes?
thank you
Message 8 of 30
ennujozlagam
okay, i hope your issues will be fixed and try to install latest updates from autodesk. thanks
Message 9 of 30
Yara-architecture
sorry, you didn't answer my last question., if i need to choose yes?
Message 10 of 30
ennujozlagam
yes. but copy the file into another folder just incase something happen wrong. thanks
Message 11 of 30
Yara-architecture
ok, i will, thank you so much i will let you know if the problem solved.
thank you
Message 12 of 30
Yara-architecture
I tried that, so after chosen yes there is nothing happens, it should give me a new message or what?
thank you
Message 13 of 30
ennujozlagam
can you share your file so we can check? thanks
Message 14 of 30
apurba
Have you downloaded the file from internet? the file may be corrupted due to not downloaded correctly.
please tic the Audit option present in the open file menu ( Left side bellow as shown on attachment)
Hope, this will help
Apurba Baruah
i7, 16GB,1TB
Message 15 of 30
ennujozlagam
dude, you are not reading? thanks
Message 16 of 30
Corsten.Au
Hi
If the file is corrupt then its difficulty to recover .
You may try these
1. Audit the file while opening.
2. if its a central file then try DETACH and open
   ( while opening, go to the WORKSETs, and uncheck all )
3. You may try opening the " Backup " files ( Example SAMPLE.001.rvt ) etc
4. If there are LINKED Revit files then Revit tries to load linked Revit files, you can change the folder name where links are saved so that while opening the file they don't load by default.
5. Learn how to recover the file from, Restore the file..its in Collaborate-Restore Backup.
Best luck
Corsten
Building Designer
Message 17 of 30
Yara-architecture
 hello, i can not attach the file, thank you for the help
Message 18 of 30
Yara-architecture
no itis not from the internet, i did what did you say but nothing happens.
Message 19 of 30
Yara-architecture
sorry, i was busy just can read your answer and replied.
thanks
Message 20 of 30
Yara-architecture
i will try that.
