Can not delete fixtures!
1 REPLY 1
info
318 Views, 1 Reply
I've never seen this before.
The model has a toilet & two different sinks we can not select (with mouse) in any view.
It's strange because there are identical toilets & sinks elsewhere in the model which we
can select fine!
The only solution (I can find) is delete the families?
Just like your feedback.
1 REPLY 1
C.Benke
in reply to: info
Only thing I can think of is the design option. Try turn it on/off and see if you can select it and also uncheck the exclude option at the bottom.
Forma Design Contest
