Can multiple people work on the same file at the same time?
nviziondesign
nviziondesign
Can multiple people work on the same file at the same time? Is it an easy process?
Accepted solutions (3)
bultekovbim
Yes, you can work on the same file at the same time. You need to create the central file, and 2 or more people can join and work together.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/video/youtube/lesson/143595-courseId...
Enable work sharing.  It is the core function and the one reason to use Revit full version.
