Can I run Revit on Galaxy Book 2?
Message 1 of 10
Does anyone have experience installing Revit on Galaxy Book 2? I would like to use it for presentation and minor changes and not for regular work.
It has a new Qualcomm Snapdragon 850 processor.
Replies (9)
Message 2 of 10
RobDraw
Revit does not run on Android, AFAIK.
Rob
Message 3 of 10
system requirements are here:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
that would have you saved you some time
Message 4 of 10
Although it runs Windows the Snapdragon processors will only run Windows Store apps, so not Revit. One option if you use BIM 360 is to present with the browser & website. Works well on even modest machines.
Message 5 of 10
Thank you!
Your answer helped me a lot
Message 6 of 10
hgrimberg
Same problem with the Galaxy Book 12”, 2-in-1 PC? There is no workaround?
Message 7 of 10
Revit requires a 64 bit OS on 'x86' type processor (typically Intel/AMD) so no workaround I know of
Message 8 of 10
hgrimberg
So then it is much better on a Microsoft Surface? Is revit 2020 optimized to work with the active pen from the Surface?
Message 9 of 10
robincapperrcd
Yes, runs OK on the Intel Surfaces (so not the new snapdragon Pro X), better on Surface Book due to the dedicated NVIDIA graphics, within the device RAM memory limits (16GB) so not vast complex models.
None of the Autodesk cad/BIM apps work very well, if at all, with pen or the surface dial, rather disappointing how poorly Autodesk have done this. Their sketchbook app does work well with pen though
Have a look at the surface related posts on my blog for more details  on Revit/cad/surface
https://rcd.typepad.com/rcd/surface/
Robin
AEC Collection & BIM 360 | Windows Surface Book & HP Z6 Workstation | Android Mobile
RobiNZ CAD Blog
Message 10 of 10
hgrimberg
Thank you for your answer. So, you said that Revit doesn't work well with the pen? So, you can't sit back and use the pen instead of the mouse with Revit on the Surface book/pro? It won't make much sense to buy it if you have to use a mouse to work on revit... I thought Revit was optimized for it by now...
