Can i import excel sheet into to revit schedule while override all data?
danezeq
Message 1 of 10
danezeq
note:  in this workflow i'll have to do it occasionally is it possible?
Replies (9)
Message 2 of 10
RSomppi
Yes. have a look at DB Link along with other 3rd party apps.
Message 3 of 10
Save excel file ad PDF and link or import the PDF in.  When update, save overwrite the old PDF and reload.
Message 4 of 10
danezeq
How should the pdf sheet override the schedule inside revit?
When i read "import pdf to revit" i imagine importing it into the model space. thats all i know.
Are you saying there is an option to import pdf into schdule?
Message 5 of 10
RSomppi
A PDF isn't going to import any model data.
Please see information about DB Link mentioned above.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2023/ENU/Revit-D...
Message 6 of 10
No.  Place the PDFs on sheet in lieu of Revit schedules.
Message 7 of 10
danezeq
that wont help beacuse i need to sync it with some parameters
Message 8 of 10
So what is the Excel for?  Just do it entirely as Revit schedule then.
Or use an add-in.
https://apps.autodesk.com/RVT/en/Detail/Index?id=6035794126247149351&appLang=en&os=Win64
Message 9 of 10
danezeq
yes i just stumbled in youtube video showing how to works. looks perfect!
oops... just find out it not working with revit 2023!
Message 10 of 10
RobDraw
Rob
