copy/paste problems (Shared Coordinates Base Point Survey Point Internal Origen)
1 ANTWORT 1
Nachricht 1 von 2
luisxv724
196 Aufrufe, 1 Antwort
When I copy element from diferent models with shared coordinates, then I paste elements, they are in the wrong place
I get the wrong, The model with shared coordinates have diferent Internal Origen Point, but same Base and Survey Point
Model A, Internal Origen point is the same as base Point
Model B, Internal origen point is displace from base point
I need to relocated all elements desplacing like green line marked. Other models have the Internal Origen displace like model B,
I want to fix the model A, maybe you know how should I do
Regards
Beschriftungen (5)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: luisxv724
