Can I have access to the resource code of the wood framing add-in?
JLFN1964
Message 1 of 14
JLFN1964
I would like to have access to the resource code of the Revit wood frame package add-in for a research purpose.
I am enroled in a Master engineering research which intends to develop a panelization automation for wood framing systems, at the University of São Paulo, Brazil.
The code will be probably written in Dynamo or even in Phyton or C#. My target is to link this new system into the Revit wood framing plugin.
Is it possible for me to have access to this code?
Thanks for now,
José Luis Fairbanks
Architect
Replies (13)
Message 2 of 14
You need to contact the author directly.
Message 3 of 14
JLFN1964
OK. By the way, where can I find the author? Do you know?
Message 4 of 14
Support Contact: rex.support@autodesk.com
Message 5 of 14
JLFN1964
Thanks, but I´ve already written to this address, and it´s been discontinued.
Anyway, thanks a lot.
Message 6 of 14
JLFN1964
I´ve tried contact at the e-mail provided, but it´s been discontinued. Is there any other way to contact the author?
Message 7 of 14
Sahay_R
Appeal to a higher authority - try contacting @Viveka_CD.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 8 of 14
Viveka_CD
Thanks for the alert @Sahay_R   (I'm just a helper...no way higher authoritySmiley LOL)
@JLFN1964 can you confirm if we are talking about the same plugin Timber Framing 2015
Let me get some more input from a dedicated resource.
Message 9 of 14
JLFN1964
Yes, I refer to the Timber Frame 2015 for Revit.
Message 10 of 14
Isn't this the intellectual property of Autodesk?
Message 11 of 14
JLFN1964
Yes it is. I just wanna know if Autodesk would give me an access for academic research.
Message 12 of 14
Viveka_CD
Hi @JLFN1964
I wanted to share the below feedback from the team:
Access to the source code is not possible.
As of now, this add-in (timber framing 2015) is not being updated and is part of the Revit extensions available via appstore.
Have you looked into other timber framing add-ins? (Check Strucoft, Agacad, hsbCAD)
@josemukalel can you provide input on timber framing?
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Message 13 of 14
JLFN1964
Thanks for the answer. I didn´t see it before.  Sorry! But that´s OK to me for now.
Message 14 of 14
Viveka_CD
Hi @JLFN1964
Thanks for getting back to us and letting me know.
