Can I delete previous text in parameters
AidanHawkins
AidanHawkins
Please see attached
How can I delete some of the history I have typed into this text parameter?
I now do not need or want half of the wall finishes I have used previously
Regards
Aidan
L.Maas
What you see there is values that are applied to the same parameter in different families in your project.
So, for example, there is one or more families in the project that has "Crepis Peint" as value in the "Wall Finish" parameter
Louis
Please mention Revit version, especially when uploading Revit files.
AidanHawkins
Thank you
So if I delete all of the ones I do not want they will not appear after that
Aidan
L.Maas
Yes, you can test this easily.
-Place a family.
-Put something in the Comments parameter (e.g "Aidan")
-Place another family.
-Open the list of the Comments parameter and you will see "Aidan" there.
-Go back to the first family.
-Remove "Aidan" from the Comments parameter
-Open the list of the Comments parameter of the second family will see that Aidan is not in the list anymore.
It is typically not something you should worry about
Louis
