Can I change curtain wall panel/type?
Right now I have just basic store front. I know you can add panels but is it possible to make the type of panels in the photo attached? Along with the frame around it (I guess the wall) ?
Use the Sloped Glazing (Roof) or Curtain System on Mass Face.
Sorry is that to slope the wall? I just want to change the panel or grid type if possible. And frame it instead of having it go all the way from floor to ceiling?
ennujozlagam
pick the curtain wall and adjust > edit profile to suit your need. thanks
martijn_pater
Not sure what panel we're talking about. To create a cw panel go to new --> family, select Metric Curtain Wall Panel family template. Model your panel, save&load it into project.
So, the only thing you were trying to illustrate with this screenshot, was a Curtain Wall without Horizontal Mullions?
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Yes sorry for not being clear, still learning terminology. I finally took out the horizontal mullions but I don't want it to go all the way floor to ceiling. Should I just put in and edit a window instead of curtain wall? I'm so used to SketchUp..
