Color of objects in 3D mode are not showing in elevations
5 ANTWORTEN 5
Nachricht 1 von 6
gtdraftdesign
1612 Aufrufe, 5 Antworten
When I view my model in 3D mode, the color of the window sash looks correct. However, the sash is white in elevation mode. Why would there be a difference between the two? I've included two attachments.
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: gtdraftdesign
create a view template from your 3D view and apply to your elevation view in see if helps .thanks
Nachricht 3 von 6
gtdraftdesign
als Antwort auf: ennujozlagam
Thank you for replying. I tried creating template from view, and the sash still is white.
Nachricht 4 von 6
ennujozlagam
have you check your setting of detail level - fine  and visual style - colours and see if helps. thanks
Nachricht 5 von 6
  • Are there your Elevation and 3D View in the same Visual Style?
  • Are there any override 2D Masking Region applied in Family Editor?
Constantin Stroescu
Nachricht 6 von 6
hmunsell
can you post the model, or at least that portion of the model, so we can look at it?
Howard Munsell
