Can I adjust wall face pattern individually without constraints to the other wall face?
julia_cheong
julia_cheong
Hello, hope you all are doing great.
I'm working on the Exterior Wall of the building in Revit, and struggling with pattern of the wall.
If I align a vertical line of the face A, the pattern of the face B also moves with it.
Is there any way I can adjust it separately?
Thank you.
jvpantin2
First of all, verify that wall pattern is a model instead of a drafting type, otherwise you won't align it.
Then, try with these two options:
-Unjoin (separate) walls and align patterns one by one,
-If that doesn't work, create parts for both sides of wall and then align them separatelly
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
kostask_oionei
Is this one wall with wrapping at ends or at inserts?
In this case I don't have problem to adjust the pattern separately.
Tab + click to select a vertical or horizontal line of the pattern and move it.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Paint the face you want to control independently with the same material prior to aligning the pattern.
julia_cheong
Thank you for your reply.
I have treid the same way, but It didn't work.
I have created the same walls on different levels, but some of them work well&some of them doesn't.
julia_cheong
Thank you for you reply.
I have tried to align them, but some of them work well, and some of them doesn't.
julia_cheong
Thank you for your solution.
It it working and I believe that this is the best way.
Thank you so much!
