Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Call-out head not masking when placed
brianwclayton1969
Message 1 of 10
brianwclayton1969
Good evening users, I have a questions that was raised and I never thought about it until it was asked.
When placing a text or dimension over a filled region the text and dimension will crop or mask out around it so you can read the text or dimension numbers BUT when you place a call-out around something or even a section marker and the head happens to fall inside or on the fill region. it DOESN'T mask around the head or information.
Why is that?
See attached screenshot.
Thanks for any assistance and answers
Accepted solutions (3)
Replies (9)
Message 2 of 10
Lachlan-JWP
If you'd like the callout head to be opaque, you can modify the family and add a masking region behind the other detail elements.
This family can be found under family -> annotations in the project browser.
Message 3 of 10
ennujozlagam
there is a workaround for this, edit your section head family, change your text to opaque, add a masking region circle in the circle and add underline as text in the middle of the circle and reload, same process you will do in your call-out head and see if helps. thanks
Message 4 of 10
brianwclayton1969
I appreciate all your assistance and answers. Yeah that's fine for me to do, but a little much for novice Revit uses.
Again I appreciate it.
Brian
Message 5 of 10
lshannonEQEBT
What do you mean by add a masking region behind  the other detail elements? Is there a way that I've been missing to arrange the order of elements?
Message 6 of 10
Lachlan-JWP
@lshannonEQEBTit depends on which elements you draw first. In the case of adding a masking region to an existing family, I would cut the existing detail elements, draw the masking region, then paste the detail elements back to the same place. They will then appear on top of the masking region.
Message 7 of 10
zwilson79H5F
FYI, this cut/paste sequence isn't working for me. The masking region still hides the horizontal line of the section callout (line between detail/page text). A hover over the callout head shows the line is there, just not a visible line.
Message 8 of 10
Lachlan-JWP
If that's not working for you, then try redrawing the lines over the masking region.
Message 9 of 10
morgan.mcnallyKEV26
Hi, Ive tried the above and this does not work. the line still does not show on top of the masking region. If i draw the masking region in two halves, it also doesnt work, as the horizontal line rotates with the text.
Message 10 of 10
charles.wermers
This is really just a joke.  This has been discussed for 15 years.  I have seen community threads from 2017 complaining that this had been going on 10 years.  Really.  Just fix it.
