Calculating Wall Surface Area
Message 1 of 10
Hello Revit Forum,
Can anyone help me in calculating the surface area of a set of walls?  I've scheduled the walls using "Material Area" and have a number, but all Revit seems capable of is giving me the, what I would call, "profile area" of each wall (one side), not the actual surface area of the object (all sides).  Does anyone have a trick for this?  The purpose is to estimate pricing for sandblasting some block walls.
Thank you,
-Rocky
Replies (9)
Message 2 of 10
Calculated Parameter=Length * Unconnected Height
maybe I misunderstood you. Are you saying you want to include the thickness profile area as well (e.g. front and sides of the material so to speak)?
Message 3 of 10
times two, plus the thickness times height, times two.  I'm looking for a way to schedule SURFACE AREA.  If you have any information that is helpful in that regard I would appreciate it.
Message 4 of 10
You can get there with Calculated Parameters.
Message 5 of 10
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question @Anonymous.
I found the following YouTube video showing a way to calculate wall areas: Finding wall areas on Revit
If the Calculated Parameter suggested by barthbradley and the video don’t answer your question, can you attach a small sample RVT showing the parameters you are working with?
Lance Coffey
Technical Support Specialist
Message 6 of 10
Schedule Parts instead.
Total Combined Areas=(2 * (Length * Height)) + (2 * (Height * Thickness)) + (2 * (Length * Thickness))
...just to be clear, create Parts from Walls first and then Schedule Category "Parts".
Message 7 of 10
Paint all the surface you want to calculate with material(s) and use Material take-off schedule to calculate the Paint areas.
Message 8 of 10
That works!  Thanks
Message 9 of 10
Out of curiosity, how do you think you are going to Paint the back and sides of a Wall Material? Neat trick if can do it.
Maybe I misunderstood.  I see now you're trying to figure the exact amount of wall surface there is to sandblast.  Geez, who'd have thunk one would need a 3D model for this.  Must have been a nightmare to calculate in the olden days.
Message 10 of 10
Do you model all of your sandblasting jobs?
