Calculating Floor Efficiency
jfjacques
Message 1 of 10
jfjacques
I want to achieve the following via Revit Schedules
The columns below are : TOTAL FLOOR AREA  and EFFICIENCY (The schedule is sorted by floor. It is also in french.)
EFFICIENCY = TOTAL FLOOR AREA / SELLABLE FLOOR AREA
I am testing my prototype floor by floor.   As you can see below, I am able to obtain the Level's efficiency value given VENDABLE: a Yes/No parameter that serves to filter out service/common spaces from AREA_VENDABLE. (Perhaps there is an automatic way to achieve this separation, but given the lack of strings as conditions, I haven't been able to figure it out. Suggestions are welcome.)  I also divide areas with their concommitant percentage of the total Level area, thereby given me the "total area" in  AREA/ AREA % and AREA_VENDABLE/AREA_VENDABLE% elements.
When I un-itemize every instance I get "varies" as there is more than one value in my AREA_VENDABLE/AREA_VENDABLE % column.
How can I work around this? I am close to something workable, but I don't mind changing the schedule if it's a dead end.
Replies (9)
Message 2 of 10
Post your "close to something workable" Project file.
Message 3 of 10
jfjacques
the schedule is "stat_X % efficacite..."
Message 4 of 10
Try this file:
Message 5 of 10
jfjacques
thx! solves the part I was missing : taking a sum total, X, appearing in every row, and placing it back as a grand total Y.
In other words, dividing X by the number of times it appears in a column, so that, when added into Y as a grand total, Y now equals the orginal X value.
Message 6 of 10
I actually am impressed that you can make out the logic just by looking at the file. Good job.
Message 7 of 10
jfjacques
Thanks. And thanks again for the solution.   Afraid to ask, but would you have an idea how to skip the "Rentable" YES/NO step? It would be nice if the schedule recognized, say, 1-4 bedrooms, as rentable without having to check them off. I was thinking this would be a straightforward conditional statements, but learned that the condition can't be  a string!
Message 8 of 10
britt_weidemann
Observer
Observer
Hi, I am looking to solve a similar issue but working in 2023 so cannot open the files attached
is it possible to explain how this is done?
Message 9 of 10
admaecc211151
Revit cannot use string for checking condition.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-A0FA7A2C-9C1D-40F3-A808-73CD0A4A3F20
One way to do similar things is to build a schedule key for your project. (Or maybe save it for your Template project too.) Then you can lock/change several room parameters by changing the key parameter.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-CD22DA24-4162-4AB2-B1D3-02CEBE918444
Message 10 of 10
admaecc211151
Here is made by 2020
