"Highlighted lines overlap" when creating Extrusion in Family
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
fletcherCAUUG
280 Aufrufe, 2 Antworten
Hi there,
I am attempting to create a Family in Revit of a 'cardboard cutout' of a pot plant. I have been doing this by importing a DWG outline of a pot plant, and then using the Pick Lines command to extrude the lines. My problem is that when I Tab-Select all the lines I get the warning "Highlighted lines overlap. Lines may not form closed loops". Even though outside of the extrusion 'mode' , there appears to be no overlapping lines? I am wondering whether it is to do with the DWG being made of splines? Any ideas on how to solve this?
I've attached the Revit file below.
Thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: fletcherCAUUG
Convert your dwg outline spline to polyline
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
fletcherCAUUG
als Antwort auf: vitorbortoncello
Cheers!
