Calculate row total, linear and non-linear components
marieHPAJL
Message 1 of 24
marieHPAJL
I am a lighting designer new to Revit and I would like to make informative schedules showing the cost of the luminaires.
So far so good.
The problem is that linear lighting  is priced in running meters. When I add linear lighting in a kitchen for instance, I add one piece on linear lighting  (thus counted as 1 in the schedule), but it might be 3m long and the price will be 3 x cost/m. In the same time I will add some other lighting that is non-linear and is priced pr piece.
So this is the situation:
I would like to do something like the following, but dont know what kind of formula I should use:
The thing is to get the prices for both linear and non-linear lighting in the same column.
Any tips?
Accepted solutions (3)
Replies (23)
Message 2 of 24
martijn_pater
I think you could use a yes/no parameter to define linear/non-linear, or a calculated lenght value. Needs a value otherwise when it doesn't have a lenght your if statement will not work. You could also have the cost calculated within the famil(y)(ies) as shared parameter to schedule directly.
In any case you need another parameter there...
Message 3 of 24
Like this:
Message 4 of 24
marieHPAJL
Hi, Martjin!
Oh, I just love parameters:)  Well, I guess I do. Have to learn some more about them though...
Message 5 of 24
marieHPAJL
Hi, Barth. Thank you for helping me out again - I will make myself a very simple sample family and try this out...
Message 6 of 24
Use this formula for Calculated Cost:
if (Length >0, (Length / 1m) * [Cost per meter], Cost)
- Cost, Cost per meter, and Calculated Cost are Number parameter for simplicity.
- Nonlinear fixtures should not have Length value, or = 0.
Message 7 of 24
I tried that. Doesn't work if the Family doesn't have the "Light Length" parameter.
Isn't this what you are prescribing?:
Message 8 of 24
martijn_pater
Perhaps try to make a kind of "Light Lenght+0" calculated value to give all of those a value? Then test that for the condition with your IF statement, not sure if that works...
Message 9 of 24
I'm done playing with it.   A Calculated Parameter using a conditional statement to evaluate a Yes/No Project Parameter is the way to go.
Message 10 of 24
marieHPAJL
This worked great!
Thanks very much to the two of you.
I still have one question though - do you think it is possible to "not itemize" and still end up with the right total price?
Now this happens:
 I
Message 11 of 24
How are you sorting? Don't sort.
Message 12 of 24
How come you don't have checkboxes in all the rows?  Is this a Multi-Category Schedule? Did you not mark some Categories for the Yes/No Project Parameter?
Message 13 of 24
marieHPAJL
That is my fault. I didn't assign the parameter in question to the ones that ended up without a checkbox!
Message 14 of 24
martijn_pater
FYI it doesn't. There doesn't really seem to be any method to do a kind of "has a value" checking other then adding a yes/no parameter for the type (or similar), as mentioned.
You could only split the schedule filtering for "has a value", one with one without but I suppose... except that would probably make it difficult to do totals...
related topic: https://forums.autodesk.com/t5/revit-architecture-forum/scheduling-cant-evaluate-a-null-nil-field/td...
(with some links to idea forum posts)
Message 15 of 24
here is an example without adding a Yes/no.
Message 16 of 24
.. Grouped and subtotaled per Type
Message 17 of 24
seems to me that the OP should buy us all a round of Solution Credits.
Just saying...
Message 18 of 24
I appreciate the "Like" @marieHPAJL, but I was more thinking we all deserved on of these tasty 'lil intoxications:
...maybe even with a garnish and tiny umbrella in them.
Bottoms Up!
Message 19 of 24
martijn_pater
Well I think post #9 summarizes it...
Message 20 of 24
I appreciate that @martijn_pater, but I think we all shined on this one. No winners or losers. It was a team effort all the way. Even, @marieHPAJL contributed to the success.  Without Marie, it wouldn't have been possible.
