Scheduling - cant evaluate a null (nil) field
dtiemeyer
Advisor Advisor
Message 1 of 12
dtiemeyer
Is it possible for Revit to evaluate a null/nil field and have the result of the test display a numeric value. My formulas work fine until they encounter a null/nil field. I've even tried the 'greater than 0' trick, with no success. HELP!
In my opinion, the green circled field should be '1'...
My other CAD is a Cadillac and I like to Revit to the Max!
Replies (11)
Message 2 of 12
My question is why are some things in the "L Estimated Demand" column returning a NULL value at all? That seems odd. It's got to have some value.
Message 3 of 12
dtiemeyer
if there are no 'Lighting' fixtures loads connected to that panel, it remains null - it does not begin as '0' like numerical values do in Revit.
Message 4 of 12
martinTstewart_Adsk
Autodesk Support
Autodesk Support
This may get more responses over at the MEP Forum.
Martin Stewart
AEC Support Specialist
Message 5 of 12
This isn't a discipline specific question.  I am not sure asking it over at the MEP forum makes the answer any different.
Message 6 of 12
dtiemeyer
Since this is a very deep question, the Autodesk rep asked me to create and post a video demonstrating the problem. Here is that video:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/ae0...
Message 7 of 12
I am not sure why they needed a video.  The behavior with Null value has always been like that.  It is not an isolated case whatsoever.
Message 8 of 12
martinTstewart_Adsk
Autodesk Support
Autodesk Support
Great Screencast. This is like a "model" screencast.
So this would be a recommendation to make for Revit improvement or enhancement. This is done at Revit Ideas.
I found two existing ideas that overlap with this:
Use empty integer parameter in formula's in Schedules
Formulas and Filters: Null Value OR Assumed Value, and Other Ideas
Please add a comment to these ideas and add your Screencast link to one or both of those ideas and vote them up. Or …post your own idea. Then promote your idea by posting a link to the idea back here in this thread.  Also, email any of your contacts that would like to see this implemented in Revit and ask them to vote too
If my reply was helpful, please "Like" or click the "Accept as Solution" button below (or both).
Martin Stewart
Message 9 of 12
gaurav_nirmalkar
Observer
Observer
Try filtering that parameter by "is greater than" and put value 1.
Message 10 of 12
dtiemeyer
@gaurav_nirmalkar
Did you try this before posting? Because it does not work.
Message 11 of 12
gaurav_nirmalkar
Observer
Observer
@dtiemeyer It worked for me.. May be I will need to access your actual problem
Message 12 of 12
dtiemeyer
