Calculate correct room area under roof
jekabs.smits
jekabs.smits
How to calculate room area that is below sloped roof with ceiling height at least 1600 mm? Do I need to draw room separation lines manually or is there a better option?
Thanks!
Yes. Use Room Separation Lines divide it up it need be.
Area? I assume you mean Floor Area in Attic.  Same deal.
Give Roombook, Buildbook and Areabook extensions a shot. It will help you out greatly to achieve what you want and give you great control over the process.
Set the level's room computation height to that line and set room
computations to area/volume.
