CAD to Earth
CAD to Earth
Message 1 of 8
CAD to Earth
Hi, I'm a new user of Revit and I've just installed the CAD-to-Earth plug in to Revit but it doesn't work. I have no idea why. The install progam said the installation was succesful but the CADtoEarth toolbar does not appear nor the 'Add-Ins' tab of the Revit ribbon toolbar. Can somebody have the amability to orient me how to solve this problem for using the CADtoEarth plug in? Thank you in advance for your support. Hans Barreth
Replies (7)
Message 2 of 8
mpeperkamp
Hi Hansbarreth,
Welcome to the Autodesk forum.
I just download and instal the CADtoEarth plugin.
It's working on Revit2014-2015-2016-2016 without any problems.
I am not sure what the problem is  but is a create plugin, thanks for that!
What you have to check is the following thing:
- what is the Revit version en are there any updates.
You can also contact the support of the plugin by the following email Adress: support@amcbridge.com
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Message 3 of 8
ennujozlagam
Have you try to login first and see if helps. Thankd
Message 4 of 8
Hi Michiel, Thank you for your answer. The Revit version I'm using is Revit LT 2017. From your e-mail, you only downloaded CADtoEarth on Revit 2014, 2015,2016 but not 2017. Can the problem arise from that? Could you try download it ffor Revit LT2017? Thank you very much in advance for your answer. Hans
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear hansbarreth
None of plugins can be used on Revits LT as there is no API in it.
See this.
http://www.autodesk.com/products/revit-family/compare/compare-revit-products
You may try this addin on full revit (even in trial mode)
http://www.autodesk.com/products/revit-family/free-trial
Rafal Gaweda
Message 6 of 8
Hi, I have a little issue, my CadToEarth is well installed, but the surface isn't creating the topography, when I press "get surface" it just appears flat...what can I do?, my Revit version is 2016.
Message 7 of 8
I have installed CADtoEarth and it appears now in the top menu of Add-Ins. However, i can not log in to this application (all CADtoEarth buttons are off). Please advise
Message 8 of 8
kelly.mcmullenUKFHL
I am currently having this same issue for Revit 2019, does anyone have a solution?
