CAD Manager
CAD Manager
cadelf
CAD Manager
cadelf
I am trying to tag and schedule shared nested window families used as transoms and sidelites in the window schedule, the links to pararameters are not working, they work fine in the door schedule, is this doable?
The parameters in the the family must be built-in or shared parameters in order to be added in a schedule in the project.
Mahmoud.Ziedan
@cadelf
As @ToanDN  stated ,in order to tag or schedule a parameter it should be a shared parameter or Revit default parmater.
If you are using the same parameters of the door (that are working),then the problem might be a duplication of the same name of the parameter .I recommend to delete and add again from your shared parameter list.
Also if you can share the family we may help you better.
Did you find a post helpful? Then feel free to give likes to these posts!
Your question got successfully answered. Then just click on the ' Mark as solution ' button.
Sincerly Mahmoud Zeidan
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
