- Mute
- Permalink
- Report
Hey ya'll,
Thank you very much for reading through and helping.
I have been struggling with linking an AutoCAD MEP file into REVIT. Initially I was linking and only seeing the drawing block load into Revit, and not the plan from model space. I then deleted the drawing block layer, and have it as a default Layout1 that comes standard with CAD. This helped REVIT decide to pull the plan from model space.
I set all line work to layer 0, color black, explode all, remove blocks, run PURGE and purge all, then run SETBYLAYER, then run AUDIT.
Scale: 1:1 inches
Revit scale inches, drawing at 3/8"
I set the CAD scale to match the Revit scale, save as copy, and link to Revit.
I have tried setting the import scale to .0375 (3/8. The decimal factor is just through testing and seeing that hundredth scale is relatively the closest) But either way the scale is not lining up. it is not .01, .02, .03, .0375 or any other predictable number. What the heck is going on here. I have not seen any online forums clearly outlining a procedure, and nor is it hosted by Autodesk. They simply advice to change the scale in properties. I'm not even seeing that. Attached is screen shot.
