Cad Link File
Cad Link File
Message 1 of 8
Cad Link File
can anyone give a solution that the link cad file is not coming properly as i attachelink cad file not coming properlylink cad file not coming properly
Replies (7)
Message 2 of 8
Alan.johnson1970
Do you have an image of what the dwg should look like?
AJ.
Message 3 of 8
find the attached cad file that linked to revit
Message 4 of 8
Alan.johnson1970
The biggest issue with your CAD file is the extents.
AJ.
Message 5 of 8
so can you tell me solution for this
Message 6 of 8
Alan.johnson1970
I would guess edit the coordinates in the DWG.
Unfortunately I'm not that proficient with AutoCAD so no Idea how to do it
AJ.
Message 7 of 8
i will check it out and thanks for your valuable reply
Message 8 of 8
What the heck are the units?!
Anyways, I can get your DWG into Revit at a custom scale of 1.0, but obviously that's not the scale based on what I'm reading in the DWG.  At a custom scale of 1.0, the DWG itself exceeds the 20 mile radius limit in Revit! So, you need to determine the correct scale.
See the attached RVT and DWG.  What I did was copy your DWG's existing elements to another DWG (BB_ST-M-130-DWG(Z02).dwg) and moved it closer to the Origin, and then I linked that one into the attached RVT file (BB_ST-M-130-DWG(Z02).rvt).
BTW: I deleted all the hatches in the new DWG.
edit...reattaching RVT and DWG. Everything fine.
