Bulk Edit Parameter Value
ppumGBNPS
ppumGBNPS
Hi, Im trying to edit all of the manufacture parameter of my window family as they are all from the same manufacture. I have been editing the manufacture parameter value of each window one by one. Im wondering if there is a way to bulk edit the parameter value all at once? Also ive tried the oneparameter from the diroots plugin but for some reason the value remain unchanged.
L.Maas
Where are those families, inside your project, or in your library on your computer?
in both cases it can be solved by a Dynamo script. When the families are in a folder on your computer the script gets more complicated
Louis
Please mention Revit version, especially when uploading Revit files.
vitorbortoncello
Did you follow this tutorial?
https://docs.dirootsone.diroots.com/docs/pages/OneParameter/OP-OneParameter.html#:~:text=OneParamete....
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
We do this quite often in Projects through a Schedule to change Identity Data primarily.  It's pretty painless and easy.   Maybe the better solution would be to leave the source/original Families as they are, and modify those only those Families that are actually loaded and used in Projects.
BTW: you can always save a copy of all the Families in a Project via Save As => Library.
Create a schedule, unitemize so the windows grouped into one row, then enter the parameter value.
handjonathan
Hi @ppumGBNPS
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @L.Maas @vitorbortoncello @barthbradley @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
